2:32 am
12:48 pm
January 27, 2011
Man, I remember researching this question on the internet before I made my final decision on what to purchase. The DEFINITIVE answer is as elusive as front locker vs rear (if you can only have one), auto vs manual, and which wheelbase is best (long or short). Good luck and happy reading.
2:44 pm
5:25 pm
January 27, 2011
"jsmorrow" wrote: Have used them on an older cj but it is a ranch only rig. Deep ruts that would fill with mud and wanted something that would allow the rig to reach hard ground without getting high centered. No on road use to speak of.
And that was the general consensus after reading more opinions, technical articles and "in-field" data than you can shake a stick at.
1 - Skinny tires: Cut through to/pack down to create hard surface (mud, light snow accumulation, water (reduces hydroplaning), etc).
2 - Flotation tires: Like the name says you stay on top of sand, dirt, water, snow and other soft surfaces. Also, bigger footprint for climbing non-horizontal surfaces (like ROCKS!).
9:14 pm
January 12, 2007
11:39 pm
I would look at what kind of wheeling you do. Narrow tires are good at cutting through mud and reaching hard ground. How much mud wheeling do you do?
Wide tires on the other hand will help with floatation over snow and give a wider contact patch on rocks. Do you do any rock wheeling or snow wheeling?
12:12 pm
January 27, 2011
Wider is better? (Old Pontiac commercial)?
Yup. You got it.
Look where E Aho Laula got Pontiac, extinction. Maybe that's a sign
Pontiac's slogan was "the wide tracker" ... track width which is another important feature. Although Pontiac's track width was no more than any other manufacturer. Talk about marketing. :dunno:
