Over the years I've ground off much of the lip on the bottom of the Dana 44 rear axle housing on my 2000 TJ leaving the diff cover vulnerable to peeling off easily. I've been using a skid plate that mounts using four of the diff cover bolts and a strap around the pinion housing. On the recent Hellhole trip the skid plate took a few hits and pulled out one of the bolts stripping the housing. At this point I've drilled and tapped the housing to the next size up but the skid plate just isn't fitting well any more. So I'm looking at new D44 skid plates.
This one from Rough Country is kind of what I'm looking for but it says it's for a JK Dana 44. http://www.roughcountry.com/jeep-jk-dana-44-rear-diff-skid-plate-799.html Is there any significant difference between a JK D44 and a standard D44 that may cause this not to work? (My D44 is a custom D44 using a heavy duty housing not a Rubicon D44.)
Another option is the Nth Degree / AEV rear diff skid for a TJ Rubicon. http://www.quadratec.com/products/16500_314_07.htm I like that it mounts to the axle tubes rather than the diff cover bolts, but it doesn't protect the very edge of the diff housing so I'd have to modify it to provide protection where I need it.
Any other ideas?
