The lowering and stretch
February 10, 2008
3:13 pm
"FAM" wrote: Is there much metal left for the fronts of the rear flares to bolt up to?
There was plenty. It is only temporary until after the Hammers and then I will put tube fenders back there.
February 12, 2008
3:16 am
The stretch is going good, I was over there today. All the old brackets are cut off and he is moving the spring buckets back tmorrow and building the new arms. We measured the wheel base where axle will sit when done and I am just over 101 inches 😀
My new roll cage comes in tomorrow, so John and I will be installing it this weekend, changing out my front axle U-joints, putting all new tie rod and drag link ends on, installing my stage 8 kit, etc....
February 12, 2008
3:20 am
Which roll cage did you end up getting?
February 12, 2008
4:59 am
I'll be there to help. We can also change the joints in my rear/uppers.
3:34 pm
"FAM" wrote: Which roll cage did you end up getting?
I went with the Rock Hard cage after talking with several shops who all said it's as good as a weld in cage if not better....It isn't a cheap either 😯
February 15, 2008
6:23 am
My Jeep is done. I will pick it up Sat. when I get back into town. He decided not to notch the frame. He moved the buckets back and it only raised the rear an inch. I have to drive it home in front wheel drive. Apparently my drive shaft doesn't connect anymore. The front half and the rear half of the shaft are about 4 inches from connecting.
February 15, 2008
3:10 pm
I'll be waiting for pictures!
February 15, 2008
3:18 pm
I know where Justin lives...we can get you a new drive line in about five minutes...bring your tools...
4:07 pm
Justin
Forum Posts: 1416
"JohnDF" wrote: I know where Justin lives...we can get you a new drive line in about five minutes...bring your tools...
February 16, 2008
3:42 pm
Today is the day 8)
4:42 pm
"JohnDF" wrote: Today is the day 8)
Tick tick tick...still waiting for pictures! 😀
February 16, 2008
4:46 pm
"Bender" wrote: [quote="JohnDF"]Today is the day 8)
Just got back in town from Tahoe. I will pick it up tonight when I get out of bed..I will try and get some photos if it isn't to dark..
February 16, 2008
5:59 pm
Justin
Forum Posts: 1416
Can I come over and play tommorrow? 😀
February 17, 2008
12:29 am
"Justin" wrote: Can I come over and play tommorrow? 😀
I am planning on about 9:00 a.m. and we can get breakfast first if anyone is up to it...
February 17, 2008
3:05 am
Breakfast in Loomis at 8 a.m. same place as last week..
February 17, 2008
3:42 am
We'll be there
2:02 am
Justin
Forum Posts: 1416
Your Jeep looks good Rob. I really liked how the rear buckets turned out.
Thank you John and Rob for helping me beat and drill on my Jeep today. I have to pull the soft top back one more time for the spreader bars and might need some help getting it back on. lol
February 18, 2008
2:25 am
Wheel base is over rated 😀
2:28 am
Here are the photos of the work.
This is how the buckets were moved back.
[Image Can Not Be Found]
The red line shows where the back of the tire used to be.
February 18, 2008
2:38 am
Looks good!
February 18, 2008
2:39 am
Justin
Forum Posts: 1416
"JohnDF" wrote: Wheel base is over rated 😀
We will see! 😈
February 18, 2008
2:42 am
troyman
Forum Posts: 404
That looks really good! Much better than the notch, I couldn't stand that notch on mine when I had it. Do you have any more pics of your rear shock mount from different angles? It looks a couple pieces of 1" or so 1/4" plate and a tube welded in the middle as a mounting sleeve, is that what it is? Nice welds too!
February 18, 2008
3:14 am
Very nice. What did the final wheelbase end up at?
February 18, 2008
3:15 am
"troyman" wrote: That looks really good! Much better than the notch, I couldn't stand that notch on mine when I had it. Do you have any more pics of your rear shock mount from different angles? It looks a couple pieces of 1" or so 1/4" plate and a tube welded in the middle as a mounting sleeve, is that what it is? Nice welds too!
Very simple shock mount, Brad had his done after I got mine. A guy I know up in Foresthill made them. Here is a link with some more photos..
https://posse4x4.org/forum/viewtopic.php ... rd&start=0
March 1, 2008
11:17 pm
Here are the flex pictures. I wanted to make sure everything worked before the Hammers. This is with the Jeep all bump stopped correctly.
Almost full flex.
Full stuff in the rear with 4 1/2 inch springs. Plenty of room
Full flex in the rear..Plenty of flex I would say!!!
