Tire width to wheel width ?
July 17, 2009
3:12 am
A 33/12.5 BFG KM2. An 15/8 or 15/10 wheel. Which one and why ? I've ordered tire & wheel package already, but due to a back order I have time to change width of wheels. (having second thoughts) idea
July 17, 2009
5:04 am
8" No question. It will hold the bead better when aired down.
6:29 am
X2!!!!
a 12.50 tire on a 10 inch rim will limit how much you can air down..15 pounds would be pushing it before you increase your chances of unbeading a tire..On snow runs, you want to be able to run between 4 and 8 pounds. You would never be able to do that on a 10 inch rim. If you were going to run beadlocks then I would say go with the 10 for the extra width.
"JohnDF" wrote: 8" No question. It will hold the bead better when aired down.
July 17, 2009
2:46 pm
Forum Posts: 7065
Yes, I agree with the previous two responses. Without question, the 8" wide rim would be my choice.
July 17, 2009
3:42 pm
"RobD" wrote: a 12.50 tire on a 10 inch rim will limit how much you can air down..15 pounds would be pushing it before you increase your chances of unbeading a tire..On snow runs, you want to be able to run between 4 and 8 pounds. You would never be able to do that on a 10 inch rim. If you were going to run beadlocks then I would say go with the 10 for the extra width.
I 100% agree on the 8", but not Rob's minimum. Eric continually shocks me with how low he gets away with running his 12.5" tires on a 10" rim. He ran the Rubicon last week at about 6-8 psi on a 37x12.50 MTR on a 10" rim. Either way, I'd be more comfortable with an 8".
July 17, 2009
4:21 pm
I've seen Justin run pretty low pressure with his 10" rims. But, it's probably always in the back of his mind that an 8" rim would be more fool-proof.
7:01 pm
Justin
Forum Posts: 1416
"JohnDF" wrote: I've seen Justin run pretty low pressure with his 10" rims. But, it's probably always in the back of his mind that an 8" rim would be more fool-proof.
Yeah, I have been running around 8psi on my 10" rims and the whole time I am thinking "I really need beadlocks". I think I have been lucky.
July 17, 2009
10:47 pm
🙂 Thanks for the input. My order was changed to 8 inch wide today when I picked up the currie steering set-up. 😀
