11:12 pm
May 4, 2004
I'm at a measly 30:1 with my 32RH auto trans, stock NP231 & 4.10 gears.
Here's a good crawl ratio calculator. http://www.grimmjeeper.com/gears.html
11:58 pm
12:51 am
Tire size does play a role...this is the calculator I used...
1:01 am
"uglyjeep" wrote: 2:1= 37:1
4:1= 75:1
8:1= 146:1and yes, tire size play a big role in crawl ratio.
Tire size doesn't have any impact on the crawl ratio. Crawl ratio is simply about gearing. Final speed has plenty to do with tires. Gearing in the axles impacts your performance when your tcase is in high (1:1).
"JohnDF" wrote: Tire size does play a role...this is the calculator I used...
From John's page
[Image Can Not Be Found]
PS...I'm at 223:1 in low low. 8)
1:54 am
"Bender" wrote: [quote="uglyjeep"]2:1= 37:1
4:1= 75:1
yeah, that's what i meant
8:44 pm
Sorry to get off topic...
But I thought the new axles for the rubicon that longfield came out with are pretty interesting.
We tested a couple stock outers and some popular up graded outers and the CV and it was impressive on how much the CV's can take and the OEM ones cant take.
OEM tested at 10 deg. of twisting and 2000-2500 FT/LBS of torque before breaking.
Popular up-grade #1 tested at 40 deg. of twist and 5000 FT/LBS of torque
Popular up-grade #2 tested at 50 deg. of twist and 4100 FT/LBS of torque
CV's tested at 75 deg. of twist and 6800 FT/LBS of torque at a FULL TURN!!!!!!!
Sounds like they need a good hammers test. 😈
12:07 am
"JohnDF" wrote: [quote="Bender"] Are they basically replacing a u-joint with a birfield type joint?
Say it aint so 😯
It's so!!
[Image Can Not Be Found] 8)
8:17 pm
Ya, I had a toyota before my jeep and I thought birfields = bad. But its impressive that at full lock the longfields are holding to 6800 ft. lbs. torque. And their suppose to not bind like u joints. And for only $850 and lifetime warrenty and don't know what to think. I think I am going to need therapy.
