After doing more winch research I've decided to go with the Smittybilt X20 Comp (synthetic rope). Can't justify spending more than double on a Warn right now.
My debate is...
Do I go with the more than adequate 10K (218:1), or go overkill with the 12K (265:1)? The winches are the same dimensions, just different ratio, line speed, and amp draw (12K has lower amp draw).
10K line speeds: 31.1ft/min@0lbs, 14.3@2000, 11.7@4000, 10.17@6000, 8.8@8000, 7.38@10000
12K line speeds: 24.6ft/min@0lbs, 11.48@3000, 8.86@6000, 7.22@9000, 5.58@12000
Thoughts?
