5:13 am
Thought I'd move this from the other thread.
The items in green are complete...
1. 1" Body Mount Lift - installed. (finally fixed an old problem where I had to cut one of the bolts. Drilled it out this time and was able to get a new nut on top. what a PITA that was!)
2. 1" Motor Mount Lift - they came bare metal so putting a coat of paint on them. I have one old motor mount loosened and ready to come out.
3. Tranny mount and torque arm bushings for #4 - still need to pick one of them up on Friday.
4. [color=#008000]Teraflex Belly-Up, Oil Pan, and Transmission skids - to be installed. I'm hoping I won't need to re-clock my Stak. I'm going to need to fab the transmission skid a little since it's made for a TJ because the YJ has the stupid crossover pipe under the tranny. (wish I knew the TJ rerouted that when I bought my headers 👿 )(old and dented Skid Row skid plate removed.)
5. Genright gas tank skid - picking up Friday.
6. MORE rear shock relocation brackets (to be used with the "other" part that is still on order).
5:19 am
3:41 am
1:06 am
2:00 am
3:38 am
4:19 pm
5:08 pm
January 27, 2011
3:13 am
The Jeep has made it's long awaited return home this evening.
Front gears, drive shaft, traction bar, Stak support bracket, and pinion angle correction are all done. Thanks Joe for seeing the incorrect pinion angle! Jason said it was WAY off!
The ride home was SMOOOOOOOOOTH!!! 😀
Things I have remaining... replace rear main seal (oil is leaking there), install oil pan and transmission skids, replace all spring bushings, replace all spring bushing bolts and sleaves with larger grade 8 greasable bolts and sleaves. I broke one of the grade 5 greasable bolts. I'm also replacing the zerks on the bolts with flush style zerks since just about all of the zerks on my old bolts are bent or gone.
4:04 am
"Bender" wrote: [quote="kevheb"]replace rear main seal (oil is leaking there)
On the engine? Hopefully that's less miserable on a Jeep than most engines I'm familiar with...
On the 4.0L you just need to drop the oil pan to get to it. Found a good write-up about it here: http://www.dailydriventj.com/forum/viewtopic.php?t=811
2:41 pm
"kevheb" wrote: [quote="Bender"][quote="kevheb"]replace rear main seal (oil is leaking there)
Doesn't look like fun, but not terrible!
2:50 pm
May 4, 2004
"kevheb" wrote: On the 4.0L you just need to drop the oil pan to get to it. Found a good write-up about it here: http://www.dailydriventj.com/f......php?t=811
Thanks for posting that write-up. I've got some oil leaks I need to take care of too. One I know is the power steering pump but I think I've also got the dreaded rear main leak too.
