Cold III
    #18 Dec 2009, 7:14 AM
    15 degrees at my house this morning, but it looks like the plumbing survived!
    #28 Dec 2009, 7:18 AM
    Mine froze again. I must have missed something :?
    #38 Dec 2009, 7:21 AM
    "Bender" wrote: 15 degrees at my house this morning
    BURR!!
  4. RobD Subscriber
    #48 Dec 2009, 8:56 AM
    Do you know where it froze? Was it your holding tank or was it in your exposed pipe line? You could build a little shed to cover your holding tank or you could wrap it with electric heat tape on nights where it is going to freeze.
    "JohnDF" wrote: Mine froze again. I must have missed something :?
  5. Fred Subscriber
    #58 Dec 2009, 8:58 AM
    It was a balmy 26 in Folsom this morning. The window guys are coming out today to work on the rest of our windows so I expect it will be close to that inside pretty soon. BRRRRR
    #68 Dec 2009, 2:03 PM
    Turns out mine froze too. 🙁 Must be somewhere between the storage tank and pressure tank because I got a shower. I went home at lunch, poured boiling water on them and still nothing. Hoping mother nature helps out and I'm headed home early to see what else I can do.
  7. JohnDF Subscriber
    #78 Dec 2009, 3:10 PM
    That sucks. At least it warms up above freezing at my house so I have water later in the day. Good luck, I hope you find it.
  8. RobD Subscriber
    #88 Dec 2009, 5:02 PM
    How far are your water lines buried? Mine are 4 feet under ground from my wellhead to my holding tank that is under my house (about 50 feet of pipe buried). I have about 18 inches of exposed pipe out of my wellhead to where it goes under ground and another 36 inches where it comes out of the ground at the house and then through the wall to the holding tank. I have the pipe wrapped with insulation tape then insulation padding around that then wrapped with insulation tape again. Mine have never frozen.
    #98 Dec 2009, 5:37 PM
    Mine froze because I'm an idiot. Everything was wrapped with heat tape. Unfortunately, I fooled the sensor on the heat tape by putting a light too close to it so it never turned on. Of course, if I don't turn on the light, the 1/4 line to the pressure sensor freezes. Needless to say I've got some work ahead of me, but I have water for now.
  10. JohnDF Subscriber
    #108 Dec 2009, 8:36 PM
    Dang...8:30 at night and my pipes are already frozen...even after all the extra wrapping I did today 😤
    #118 Dec 2009, 9:38 PM
    i lost a pipe as well. maybe more once thet thaw and start leaking.
    i got my first snow run in , my driveway!
    #128 Dec 2009, 9:41 PM
    "JohnDF" wrote: Dang...8:30 at night and my pipes are already frozen...even after all the extra wrapping I did today 😤
    Bummer! It's cold out there tonight. It's already 22 up here.
  13. JohnDF Subscriber
    #138 Dec 2009, 10:00 PM
    It's already 25 here 😲
  14. JohnDF Subscriber
    #149 Dec 2009, 7:09 AM
    Ha...it wasn't frozen pipes last night, it was clogged from the sediment. All is good this morning 😁
    #159 Dec 2009, 7:47 AM
    I't been 15-25 degrees in DC these past three days, but since it's been clear with very little wind, the days have been fine. Our house still has snow, so it must be staying cold...
  16. Dan-H Subscriber
    #169 Dec 2009, 6:35 PM
    "BKGM Jeepers" wrote: I't been 15-25 degrees in DC these past three days, but since it's been clear with very little wind, the days have been fine. Our house still has snow, so it must be staying cold...
    there's still snowmen around the neighborhood.
    Lastnight got down to 26 and only warmed to the low 40s
  17. Anonymous former user
    #1710 Dec 2009, 8:50 AM
    Isn't DC full of Snowmen all year round?
    #1814 Dec 2009, 7:19 PM
    I took the garbage out tonight and heard water running like crazy. My neighbor's place is just a "summer cabin". I went down to check it out and it turns out they broke at least three pipes. One under the deck hosing down the driveway, one that feeds the water heater (which is outside) which may have been spraying water outside, and one at the well head. The one at well head broke upstream of the shutoff. The well has been running for days. I had to turn the power off at their house to get it to stop. I can't believe they didn't drain the system for the winter. 🙄
