Dang pipes are frozen this morning.
It's cold
JohnDF SubscriberJohnDF SubscriberI used to wheel a lot. . .
Fred SubscriberFred SubscriberTomorrow morning is suppose to be even colder. Last I checked it'll be 26. π²
JohnDF SubscriberJohnDF started this SubscriberShould I leave some water running at night? Does that really work?
It was 22 when I woke up this morning. Now it's 27 and cloudy. Gotta turn the Ford around and back in the cars. Bring on the snow! π
"JohnDF" wrote: Should I leave some water running at night? Does that really work?
Do you know where it's freezing? I missed the 6" section that came out of the ground into the house and that froze one year. Easy fix. Look for any exposed pipe and wrap it in insulation. Use a high quality tape (that black gorilla tape works great) over the foam and it will last for years and keep the water out. I've also had trouble with the pressure switch freezing. I called the pump place and they said there's not much you can do but keep it warm. It's only a 1/4" pipe so it freezes quick. I leave a light (the old school-non energy efficient kind) on in my pump shed and the large exposed pipes from my tank to the shed are wrapped in electric heat tape and insulation. As I remember, most of your stuff is out in the open. Can you cover it somehow? My neighbor wraps his whole pressure tank/pump setup in insulation and throws a tarp over it.
To actually answer your question. Yes, leaving the water running works. But since you'll be running your pump off and on all night, it'll show up on your power bill and there are cheaper ways to do it.
JohnDF SubscriberJohnDF started this SubscriberThanks Keane. The only exposed part right now is the pipe coming out of the well. I had it wrapped, but the dogs keep chewing off the insulation. We are going to go to Lowes and get one of those fake rocks to put over it. After that, the only exposed part will be the holding tank.
The weather is here! Starting to hail/snow. Figure I'll lose the internet in 3...2...1...
Dan-H SubscriberDan-H Subscriber"JohnDF" wrote: but the dogs keep chewing off the insulation.
spray it with PAM, then dust it with cayenne pepper. (the PAM is the "glue" for the pepper"π
sooner or later the dogs will learn this isn't worth chewing.Closed Mondays.
JohnDF SubscriberJohnDF started this SubscriberToo much work. I'd have to repeat the process of wrapping, spraying, and dusting too many times before my stupid dogs would learn the lesson.
I used to wheel a lot. . .- Anonymous former userAnonymous former user
Snow in Sacramento? The paper is forecasting snow Monday morning? Can it be true?
Dan-H Subscriber- Guest former userGuest former user
"Dan-H" wrote: must be global warming π
or the seahawks won a game... π π π π
