Rob, wake up so we can get started on my Jeep π
I'm just sitting here waiting for him to call me...tick-tock...tick-tock...
John's Jeep work day
JohnDF SubscriberJohnDF SubscriberI used to wheel a lot. . .
JohnDF SubscriberJohnDF started this SubscriberIt's 9:00. I'll wait until 9:30 to call, he's usually up by then. I just don't want to be rude since he's being nice enough to help me.
<edit> He called...he was out shopping...on my way there πI used to wheel a lot. . .
Fred SubscriberFred SubscriberDid you check your Facebook page? π
I think the Posse Board is John's personal Facebook. π
Justin SubscriberJustin SubscriberDo you need any help when I gett off of work?
JohnDF SubscriberJohnDF started this Subscriberwe managed to get the whole front end of the Jeep torn apart today. I have to replace my whole drag link (including TREs), get my pitman arm and steering arm reamed, and replace front brake calipers. I'm also refabbing my track bar. Right now, it's sitting in peices at Rob's house. We'll finish it tomorrow night (fingers crossed).
Didn't you just put new calipers on? What happened that destroyed them?
JohnDF SubscriberJohnDF started this SubscriberNot entirely sure. The right one was froze up and dragging.
So far;
replace both brakes (seized)
replace pitman arm (bent)
replace drag link (bent)
replace TREs (blown and bent)
replace shocks (worn)
tightened RE joints (loose)
lengthened control arm (bent)
rebuild track bar (bushing was shot)
chisel out the busted hub (broke)
replace with new hub
recenter front axle.
re-align toe-in to spec.
...and that's just the front of the Jeep, next month we can tackle the rear πI used to wheel a lot. . .
JohnDF SubscriberJohnDF started this SubscriberAnd a huge THANK YOU to Rob, who is still working on my Jeep even though I'm sitting on my butt at home. A better wheeling buddy there never was π
JohnDF SubscriberJohnDF started this SubscriberI think the Little Sluice and three years at the Hammers took their toll on my poor Jeep. At least it all held together...never wash your Jeeps π
JohnDF SubscriberJohnDF started this SubscriberRob has been slaving away at my Jeep. I'm heading over there soon to bleed the brakes, align the front end, and put in the rear shocks. I'll put my newly balanced tire on tomorrow and I should be good to go on the Rubicon and Barrett.
"JohnDF" wrote: Rob has been slaving away at my Jeep. I'm heading over there soon to bleed the brakes, align the front end, and put in the rear shocks. I'll put my newly balanced tire on tomorrow and I should be good to go on the Rubicon and Barrett.
What is Rob's hourly rate? I need someone to put my new u-bolts on for me. π
JohnDF SubscriberJohnDF started this SubscriberMy Jeep drives much better. But, I still need to put hiem joints in my track bar because I still get some wobble. We also discovered that my fron axle tube is bent, which is causing it to pull left. I really Hammered that Jeep π
Bad news on John's Jeep, it looks like his front axle tube is bent. My suggestion John is that you don't wheel your rig until you figure out what you are going to do. If it is infact bent, you are going to wear out your air locker due to the fact your axle shafts are not going into it straight like they should.(Don't end up costing yourself more money than it is already going to be) This is most likely the reason your axle seal went out earlier this year.
We can strip it down and take it to WFO and see if it is straight or bent and what your options are. You might only have to re-tube one side depending on where the bend is.
I am willing to bet big on where you bent it. Winch hill 3 trying to make it through the squeeze. You get yourself wedged in there pretty good and that is a ton of pressure being put on your tires and axle...
Just remember, better to be down a short time that a long time!!!!__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan
JohnDF SubscriberJohnDF started this SubscriberBetter to run it and blow it up π
You aint going to get out of running the Box that easy π
One more run and we'll park it...I'll just baby it...unless I have to strap you home.I used to wheel a lot. . .- Guest former userGuest former user
How do you tell that it is bent? Is it bad enough to just look at it and know?
JohnDF SubscriberJohnDF started this SubscriberNow, it might not be bent...I think Rob is looking to get out of running the Box :rasta:
"JohnDF" wrote: Now, it might not be bent...I think Rob is looking to get out of running the Box :rasta:
You guys should probably stick to Strawberry.
"Bender" wrote: [quote="JohnDF"]Now, it might not be bent...I think Rob is looking to get out of running the Box :rasta:
strawberry??? did somebody say strawberry? who's going? π π π
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"lowrider" wrote: [quote="Bender"][quote="JohnDF"]Now, it might not be bent...I think Rob is looking to get out of running the Box :rasta:
You're not. Didn't you break on that trail? πKathleen and Brad- RobD SubscriberRobD Subscriber
5 plus years of extreme wheeling and zero maintenance has taken its toll on Johns rig. I have pretty much rebuilt all of his steering components, built him a new trackbar with heims on both ends, centered his front axle, got both the front control arms back to the same length, got the rears back to the same length, did maintenance on the front control arm joints. Looks as if his death wobble problem is now gone!!!
His Jeep is still pulling to the right. Most likely cause is a bent spindle (checked and not bent) bent C, his camber is about -10 degrees on the driver side. It should be 0 like the passenger side, we still need to check that, or it is a bent tube....Other causes could be shot bearings; both the front inner and outer bearings are toast. Rear bearings could be shot (making a clicking sound back there)
Next we will replace all the bearings and races front and rear and see if that cures the pulling problem, fix his broken passenger side upper rear control arm. Service all the rear control arm joints, and replace all the rubber bushings back there..
I am hoping it's just the bearings causing the pulling problem, if not hoping the C because, because it can be cut off and replaced for a reasonable cost. To pull and press a new tube will cost him about 6 to $800 π__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan - Guest former userGuest former user
my goal is to only break on strawberry because of its reputation of being hardcore. π
JohnDF SubscriberJohnDF started this SubscriberDrove it home tonight. Big difference. The front end is rock solid. Still pulls to the right though. Tomorrow I need to get a broken control arm bolt removed, replace the other broken hub, re-align the steering wheel, and put the newly balanced tire back on.
Then, I have to replace all the axle bearings, service all the rear control arms, and clean out my diffs. I'm suprised this Jeep held together with as many things that was wrong with it. Just remember, never wash your Jeep, it won't fall apart πI used to wheel a lot. . .
JohnDF SubscriberJohnDF started this SubscriberDang!!! I have to do my own work on my Jeep today π
Thanks again Rob. My Jeep hasn't felt this solid in years.
I'll take a picture later of all Rob's handy-workI used to wheel a lot. . .
JohnDF SubscriberJohnDF started this SubscriberI just spent the last four hours working on my Jeep. I got all the beadlocks torqued, the new tire put on, re-aligned the front axle, and re-centered the steering wheel. I took it for a test drive and it is finally tracking straight. This is the best my Jeep has driven in YEARS!!! Now I have to repair one control arm and put in a new hub.
This winter I am going to drain and refill all the fluids, change all the bearings, service the rear control arms, and out-board my rear shocks.I used to wheel a lot. . .
