Mike G said
My neighbor came and talked to me today and said he heard a horn going off for almost 30 he went out side and started walking towards the noise and then the jeep just went up in flames.
Not sure if that means anything cause I know nothing about it but in my job anytime I see a burned car I think they couldn't afford their payments, but that's not my case I own it outright
Almost 30 minutes or seconds? If there were no visible flames and the horn was going off then I would highly suspect an electrical fire provided the eye witness account is reliable and correct. How well do you know your neighbor? Can he be trusted? Having responded to a lot of vehicle fires in my years as a firefighter, this vehicle was clearly well involved when fire arrived on scene. That means that fire had a good head start before being reported, the response time was long, there was a good fuel source, or ???. Newcastle Fire is administrated by Placer Hills Fire District where I served. I will do some checking for you Mike. I would want to know the time the fire was reported and the time that fire arrived on scene. Given that you live close to the fire station, this should not have been more than 10 minutes. That's still plenty of time for an electrical fire to do significant damage but typically those fires occur under the hood. The hood contains the fire to some degree so it is unusual to see that kind of fire damage in the passenger compartment if the fire were to have originated in the engine compartment.
The next most logical electrical fire source would be in the dashboard area where there is a lot of wiring and a lot of plastic to burn. However, with the ignition off I don't know what might have caused the fire. The second set of pictures appear that the most intense heat was towards the real of the vehicle. Was the fuel tank involved? If the fuel tank was involved and if the source of the fire was a fuel leak then why would the horn have sounded before flames were visible and what was the ignition source? And why didn't your neighbor come over and wake you up after reporting it ( I assume he was the reporting party) if he knew it was your vehicle on fire? Was the Jeep parked in front of your house or your neighbors? Your neighbor claims that the Jeep wasn't on fire when he first saw it. Correct? And when fire arrived it was that involved? If I were investigating this fire I would have a lot of questions for your neighbor.
If the hardtop was on and if the vehicle was totally closed up tight then it may be possible that the fire occurred in the cab, smoldered for some time, was oxygen starved, sounded the horn and then vented and erupted in flames just when your neighbor came out. Or as we say in the fire service, it could have been mice with matches!
