Enough snow already! 😁
Would anyone be interested in a Hell Hole run on 5/21?
5/21 - Hell Hole Run
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009
Josh Subscriber- Guest former userGuest former user
If I get my air system figured out, I am in.
"Josh" wrote: Where is this located Kevin?
Hell Hole Reservoir. About 1/2 hour as the crow flies and 3 hours as the Jeep drives. 😀
http://maps.google.com/maps?f=q&source= ... rvoir&z=13
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009Has anyone gone in through Foresthill? The last couple of times we met in Georgetown but going in from Auburn through Foresthill would cut the 40 minute (Google Maps time) drive to Georgetown.
According to Google Maps it's the same amount of time from Auburn to Hell Hole as it is from Georgetown to Hell Hole (2hrs 5min).
If Georgetown is more central for everyone that's fine. Either way I'm in if there are enough vehicles! 😀- RobD SubscriberRobD Subscriber
There are three different ways to get to Hell Hole from Forest Hill....
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009"RobD" wrote: There are three different ways to get to Hell Hole from Forest Hill....
Here's the directions Google Maps gives from the Starbucks near Foresthill Rd to the trail head. Not sure how accurate it is. Might need someone with an accurate odometer or GPS for some of the turns. 😀
http://maps.google.com/maps?f=d&source= ... 91953&z=11- RobD SubscriberRobD Subscriber
Fastest route is route 2 via Robinson Flat. You don't have the canyon and all those 20 mile an hour turns to deal with. Google map does not take that in to consideration.
"kevheb" wrote: [quote="RobD"]There are three different ways to get to Hell Hole from Forest Hill....
http://maps.google.com/maps?f=d&source= ... 91953&z=11__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009Larry, are you still in?
Josh, or anyone else interested in going?
For those that haven't been there here's a link to some pictures from last year's run.
http://pics.posse4x4.org/v/20100626KH/
This trail is rated Moderate by the Posse Trail Rating System. 😀- Guest former userGuest former user
I'm a maybe right now. I'll be certain by Tuesday of this week.
"kevheb" wrote: Larry, are you still in?
This trail is rated Moderate by the Posse Trail Rating System. 😀Cole and I are both in.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003For some reason this doesn't show on the calendar of upcoming runs. Should it be added?
Oh, and I've got a good stack going of raffle prizes for the next club meeting.Kathleen and Brad
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009"BKGM Jeepers" wrote: For some reason this doesn't show on the calendar of upcoming runs. Should it be added?
I added it to the calendar.
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009So far we have...
Larry & Cole
tgnelson (maybe)
Kevin
Let's meet in Georgetown @ 8am.- Guest former userGuest former user
I'm in where will we be meeting in Georgetown?
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009"kevheb" wrote: So far we have...
Larry & Cole
tgnelson (maybe)
Mark
Kevin
Let's meet in Georgetown @ 8am in front of Worton's Market on Main St.- Guest former userGuest former user
Kevin, with all the new snow this week, I am going to pass on this weekend. I am done with the snow. 😢
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009"GonZo" wrote: Kevin, with all the new snow this week, I am going to pass on this weekend. I am done with the snow. 😢
Yeah, I'm not up for a snow run. It's supposed to be warmer and sunny later in the week. How low is it snowing and is it going to stick?
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Snow is expected in the 4500 to 5500 ft range, with considerable snow above 6000 ft. So far about 1 ft has fallen at the 5000ft range. I believe this is just above the hell hole elevation. It might make for an interesting run Sat. There would probably be very little snow, but a lot of mud. Also, it is supposed to be 79 on Thursday and 76 on Friday. Saturday will be a little cooler.
Kathleen and Brad- RobD SubscriberRobD Subscriber
SNOW SUCKS 😤
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003I thought snow made easy trails more difficult?
Maybe there are some nice trails around Auburn?Kathleen and Brad
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009Here's the latest. They have the snow level at 5000 ft. Hell Hole surface elevation is at 4630 ft. and the trail head looks to be around 5400 ft according to this. I'll keep an eye on things.
CAZ069-172300-
WEST SLOPE NORTHERN SIERRA NEVADA-
INCLUDING THE CITIES OF...BLUE CANYON
330 AM PDT TUE MAY 17 2011
...WINTER STORM WARNING IN EFFECT UNTIL 5 AM PDT WEDNESDAY ABOVE
4500 FEET...
.TODAY...SNOW SHOWERS AND RAIN SHOWERS LIKELY IN THE MORNING...
THEN SNOW SHOWERS AND RAIN SHOWERS IN THE AFTERNOON. HIGHS 29 TO
39 HIGHER ELEVATIONS...37 TO 47 LOWER ELEVATIONS. SNOW
ACCUMULATION UP TO 2 INCHES. SNOW LEVEL 5000 FEET. SOUTH WINDS
10 TO 20 MPH.
.TONIGHT...SNOW SHOWERS AND RAIN SHOWERS. LOWS 23 TO 33 HIGHER
ELEVATIONS...31 TO 39 LOWER ELEVATIONS. SNOW ACCUMULATION OF 3 TO
6 INCHES HIGHER ELEVATIONS. SNOW LEVEL 5000 FEET. SOUTH WINDS
10 TO 15 MPH.
.WEDNESDAY...MOSTLY CLOUDY. SNOW SHOWERS AND RAIN SHOWERS LIKELY IN
THE MORNING...THEN A CHANCE OF RAIN OR SNOW SHOWERS AND A SLIGHT
CHANCE OF THUNDERSTORMS IN THE AFTERNOON. NOT AS COOL. HIGHS 34 TO
44 HIGHER ELEVATIONS...46 TO 56 LOWER ELEVATIONS. SNOW ACCUMULATION
UP TO 1 INCH. SNOW LEVEL 5500 FEET. WEST WINDS UP TO 10 MPH.
.WEDNESDAY NIGHT...MOSTLY CLOUDY WITH A SLIGHT CHANCE OF RAIN AND
SNOW SHOWERS IN THE EVENING...THEN MOSTLY CLEAR AFTER MIDNIGHT.
LOWS 25 TO 35 HIGHER ELEVATIONS...33 TO 43 LOWER ELEVATIONS. SNOW
LEVEL 6500 FEET. NORTHWEST WINDS TO AROUND 10 MPH SHIFTING TO THE
NORTHEAST AFTER MIDNIGHT.
.THURSDAY...MOSTLY SUNNY. NOT AS COOL. HIGHS 43 TO 53 HIGHER
ELEVATIONS...58 TO 68 LOWER ELEVATIONS. NORTHEAST WINDS TO AROUND 10
MPH IN THE MORNING BECOMING LIGHT.
.THURSDAY NIGHT...MOSTLY CLEAR. LOWS 32 TO 42.
.FRIDAY...MOSTLY SUNNY. HIGHS 50 TO 70.
.FRIDAY NIGHT...MOSTLY CLEAR IN THE EVENING THEN BECOMING MOSTLY
CLOUDY. LOWS 35 TO 45.
.SATURDAY...MOSTLY CLOUDY WITH A CHANCE OF RAIN SHOWERS. HIGHS
48 TO 68.
.SATURDAY NIGHT THROUGH SUNDAY NIGHT...MOSTLY CLOUDY WITH A
CHANCE OF RAIN AND SNOW SHOWERS. LOWS 30 TO 40. HIGHS 45 TO 65.
.MONDAY...MOSTLY CLOUDY IN THE MORNING THEN BECOMING PARTLY
CLOUDY. A SLIGHT CHANCE OF RAIN AND SNOW SHOWERS. HIGHS 45 TO 65.
TEMPERATURE / PRECIPITATION
BLUE CANYON 34 31 43 / 90 90 50
I would still go, with warm weather starting tomorrow, the trail will be fine by Sat. I would have gone, but I signed up to work 18 hours of overtime from Sat through Sunday morning... Cha Ching 😁
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"BKGM Jeepers" wrote: I thought snow made easy trails more difficult?
And Hard trails easier 😁
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003So Hell hole should be harder going in and easier going out? 😀
