2:30 am
Offline"FAM" wrote: What's the story with the axle problem?
All I know is he tore the ears off of both shafts on winch hill two.
I hear that Richard's truck looks a little different than when he started the day ![]()
Now he'll know I wasn't kidding that the trail gets significantly harder after the river crossing ![]()
3:52 am
Offline4:41 am
January 12, 2007
Offline4:42 am
January 12, 2007
Offline7:25 am
January 20, 2009
OfflineI made it home okay. I still had my stock YJ disconnect axle so I pulled the fork out of the vacuum disconnect and was able to drive home. To be honest, I don't know when it actually broke. In hindsight I did notice a noise every now and then but just assumed it was from bouncing around. It must have been hanging by a thread on winch hill 2 and then it seemed much harder all of a sudden and spit out the u-joint. No big boom though. 18 1/2 years on stock axle isn't bad though! What a huge difference between having a front locked axle and then not!
Overall, it was a fun run! Especially the last river crossing when the water came over my hood for a split second! You know it's deep when you can't see Rob's tires! 😀
Now, what to do? ![]()
Oh, I'm out for the Barrett run on the 13th. 🙁
Kevin
2:11 pm
January 20, 2009
Offline2:49 pm
Offline2:58 pm
January 20, 2009
OfflineThere's a good one of Don taking on water. There's also a good one of Chuck on winch hill 1. Who can spot the missing piece on Chuck's Jeep? 😀
Kevin
3:06 pm
OfflineKevin,
If you go to a junk yard or call up some of the 4wd shops, they probably have some really cheap TJ axle sets sitting around. It wont take very long to fix your Jeep. You will need to pull your carrier now and replace the seal on the side with the broken shaft. It is more than likely toast after having that shaft wobbling around in there.
"kevheb" wrote: D'oh!
4:38 pm
I may have 2 stock TJ front axles that are some what complete still hanging around if the buzzards haven't picked them over too bad. All I know of for sure is that Lee used the carrier and the unit bearings from mine that was removed when it had 30k on it and Sue's were from a 05 LJ with about the same. Do you want me to ck on them?
5:00 pm
January 20, 2009
Offline"SLM" wrote: I may have 2 stock TJ front axles that are some what complete still hanging around if the buzzards haven't picked them over too bad. All I know of for sure is that Lee used the carrier and the unit bearings from mine that was removed when it had 30k on it and Sue's were from a 05 LJ with about the same. Do you want me to ck on them?
That would be great! I just need the shafts. Then I can pick up some new seals and be back on the trail! 😀
Or I could just have Rob tow me through each run.
That worked great. Thanks for getting me out! ![]()
Kevin
10:56 pm
OfflineSo what was the damage total for all the groups. The ones that went to the committee and the ones who went back to Eagle lake?
Our group
Rob = Small finger tip scrape in the paint on the driver rear tube fender
Kevin = Busted front passenger axle (Inner and outer shaft)
Chuck = Ripped the rear driver fender flare off his Jeep
Richard = 5 or 6 new good size dents, moved his front bumper up about 6 inches on the driver side, bent his tie rod worse than any tie rod I've see in awhile.
How about the other group?
Kevin's description of the committee crossing didn't do it justice. When I looked back at Kevin, I couldn't see his hood. I saw water lapping up to his windshield. Chuck had water in his lap. I had water about 4 inches below my driver side door window frame. My elbow got wet. Richard had water going over his hood too..Very doable, but very deep!!!
11:17 pm
Offline11:35 pm
January 12, 2007
Offline8:42 pm
January 12, 2007
Offline"RockinCrawler" wrote: Looks like my front differential is toast. It was a LSD so its no surprise that it died on WH2. I've got a detroit locker laying here but need to find a Toyo 8" open carrier.
My buddy has a complete dropout out of a 4cyl Toyota he wants $40 bucks for, or you can strip the carrier for free and give him back what you don't use.
3:09 am
OfflineThey really suck in the snow 😯 😯 😯
"Bender" wrote: [quote="RockinCrawler"]Looks like my front differential is toast. It was a LSD so its no surprise that it died on WH2. I've got a detroit locker laying here but need to find a Toyo 8" open carrier.
You sure you want a detroit in the front? I hate my full locker in the front.
