7:19 am
Hi everyone,
Is there anyone interested in joining Huck and I on a Fordyce day trip? Please let us know and I will fill in the details of a meeting place in a couple of days.
Please know Fordyce is a difficult trail and you should have a rig capable of completing the trail. I would suggest a minimum of 35s and built axles. But if you are interested let me know.
4:08 pm
6:21 pm
Gilbert & Betty said
Do you know what the flow rate is, Or expected to be?
I don't think there is any way to predict the flows, especially because flows are influenced by hydroelectric demands and because of the start of the PG&E construction project. Since the committee crossing exit is closed due to the construction, this will have to be an out and back or a full trail run.
7:01 pm
7:51 pm
8:08 pm
Ok so what I'm hearing is do to construct of the Emergamcy exit. And the current position of the sun in the morning, plus available sun spot count will affect the flow rate and water level. And the trail can only be ran at night east to west. Lol
So does that mean your in?
9:06 pm
9:39 pm
October 28, 2016
4:23 pm
10:40 am
3:46 pm
October 28, 2016
8:26 pm
Brian said
Mike G said
If I can get my rig green stickered I'm down to go as long as there's a place to park my truck and trailer there. I've never been there so no clue...
You’d have to turn around and go back to the start. Since it is a through end to end trail.
Nevermind I just found out my daughter's make a wish trip to Disney world is that week so I couldn't do it anyways. I'll wait till next time and run my Zuki-stein as it is a street legal rig
8:49 am
6:25 am
4:59 pm
September 25, 2011
5:03 pm
September 25, 2011
I saw this post so I thought I would chime in. Today the flow is 287. Attached is a graph showing the flow for the past 30 days and it is on a steady decline. I anticipate the flow to be well under 300 on Saturday. There is a web-site where we can check the flow day of. I have done the trail several times and taken the mid trail exit. I really want to complete the trail as it is a bucket list item for me. So the plan is all the way through.
6:20 pm
So are Jeff and Brian still interested?
Still interested. I have some noise in my steering (u-joint, steering box, bushing, or?). I have had it for some time but it is worse after running Fordyce WH 5,4,3 to crossing at committee and then running back up WH 3,4,5 on a run at Sierra Trek last week. I will need to check it further before committing. I think the highest flows that I have run Fordyce on were about 180 CFS if I recall correctly (Kevin or Brian, can you recall?). I have a TJ with a 4.5 lift on 35's so I wouldn't want to hold the group up if you are comfortable crossing at a higher flow rate.
11:57 pm
September 25, 2011
3:19 pm
Yeah I think my power steering pump is what was chattering at me when I turn the wheel after the Sierra Trek the other week. Fixing that this weekend along with the fuel lock ring issue where it popped off the tank and I was spilling fuel for the last two hours. Y'all have fun.
7:47 pm
September 25, 2011
1:53 pm
10:20 am
October 28, 2016
10:48 pm
