1:28 am
Larry just got his Jeep back from the Doctors and wants to go for a bit of a shakedown run. We figure dirt roads are better than Praire City. 😀 We're going to meet in Grass Valley around 8:15 on Sunday 6/1. We'll probably head up 20 toward Washington. I'm not sure what to expect, but it'll probably mostly be dirt roads with some snowy spots. All are welcome.
We're meeting at the Flyers on Brunswick. From Auburn take 49 to Grass Valley. Go through Grass Valley and take the Brunswick Exit. Turn right and the gas station is about a block down on your right.
Post here or send me a PM if you're interested so we're sure to wait for you.
12:49 am
Justin and I shook down little bit of Fordyce trail today. We went in to the first river crossing and returned back toEagle Lakes area. There was some interesting off-camber spots. On the way back up from the river, I decided to stretch my new winch cable out, and even though is was steel, it did the job nicely.
[Image Can Not Be Found]
2:25 pm
January 12, 2007
"Bender" wrote: Larry just got his Jeep back from the Doctors and wants to go for a bit of a shakedown run. We figure dirt roads are better than Praire City. 😀 We're going to meet in Grass Valley around 8:15 on Sunday 6/1. We'll probably head up 20 toward Washington. I'm not sure what to expect, but it'll probably mostly be dirt roads with some snowy spots. All are welcome.
So, now that we totaly hi-jacked this thread, how was your day Larry and Keane? How did Larry's Jeep do?
6:41 pm
It was a good day. Larry's jeep did well, but he's got some driveline angle issues to take care of. He went with ARBs front and rear and new gears. Plus, they took care of some things that weren't done right the first time around.
I hate my new powersteering pump. My leaky old pump worked better at an idle than this one. It's ok if you rev the engine. I'll probably pull it and return it after Fordyce this weekend.
It was also good to get out and check out some of the TNF since the should have their Route Designation info out this summer. 🙄
8:39 pm
"Bender" wrote: [quote="Justin"]
On your pump, you might try a smaller pulley. I had to do that with my system to get the low end RPMs I needed for the pump. I went from a 5 1/4 to a 4 1/2 pulley wheel.
