Signal Peak 2022|Page 2|Trail Runs / Events|Forum|Gold Hills Posse 4x4
Signal Peak 2022
Signal Peak 2022 Trail run and Pot Luck
May 9, 2022
11:15 am
Forum Posts: 1991
buckallred said
assume this will be the "difficult side" (not the "easy side" we did on a night run)? thanks
-K5 is getting axles and lockers any day now. . .
As far as I know, the easy side is still closed due to construction at Fordyce Lake. I have been up to Signal Peak on Memorial Day weekend when there was snow on the north side preventing vehicles reaching the top. You guys might want to ask on some of the 4X4 forums to see if anyone has made it to the top yet. Congratulations on the upgrades Buck!
6:48 am
Forum Posts: 1446
sp_UserOnlineSmall Online
This is why I said "snow depending". There is snow on the ground at Cisco Grove at this time. The last 1/2 mile to the top is off-camber & has lots of ice due to the wind. We've made it up in the past...barely! Jeff's advice is a good idea.
May 10, 2022
12:25 pm
Josh
Forum Posts: 1630
I will do advance recon of the trail area before the run. If there is still a lot of snow I will postpone the run. Safety first.
12:28 pm
Josh
Forum Posts: 1630
The plan:
Signal Peak 2022 Trail Run
Who: Club members only
Club minimum vehicle requirements apply. See club website for details.
When: Friday May 27th
Start Time: 9:00 a.m
Where: Hwy 80. Exit 165 Cisco Grove. Meet at the Texaco Gas Station area. Then drive to the trail from there.
What: Be on the trail by 10. Up the “Difficult“ side. At the top of Signal Peak around noon. Do pot luck lunch. Head back down the trail once enough of the view has soaked in.
Required: A positive attitude and a willingness to help others on the trail. Be prepared to help and spot others as needed. Have fun!
Pot Luck: I will bring lunch meet and rolls to make sandwiches. If others can bring all the fixings, cheese, chips, salads, drinks, deserts, etc… If you bring chili it should  include beans.
Who’s  going:
Josh - Lunch meet & rolls
Brian (Folsom4Rnr) - Plates and napkins
Guy & Linda -Snow depending (I hope we get some)
Brad - Condiments, Lettuce, & cheese
David
Gil - Water & Soft drinks
John (Slowguy) - Chips
Kevin - Cookies / Brownies
Greg
Jamie - Maybe
A day in the Jeep on a trail priceless!
11:07 am
Forum Posts: 7420
Will you postpone?  I have the day off for the run.  Maybe you switch to Hell Hole if you have concerns about snow determining the run decision?
2:49 pm
Gilbert & Betty
El Dorado Hills
Forum Posts: 1445
sadI have to back out a VA appointment became available on that day.  So, I had to take it.  Can someone please pick up my slack? and take waters and soft drinks, thanks in advance.
May 11, 2022
8:08 pm
Forum Posts: 1991
I wouldn't cancel this run even if it looks like you may not be able to make it to the top of signal peak. You could run up as far as you can and if you can't make it to the top, you could head back down and take a run up the Fordyce trail (very moderate trail for a good distance) and make a day of it on both trails. You could also go to Eagle Lakes from the Fordyce trail at the branch just past driveline hill. Fordyce and Signal Peak trail share the same staging area, so you have both options. I'm sure you can get some good reports on trail conditions a day or two before the run so you should be able to have a fantastic day on one or both trails.
7:20 am
Forum Posts: 7420
Thanks Jeff.  I'm good with that too!
9:16 am
Forum Posts: 1446
I will be there, will probably bring chips
May 14, 2022
10:02 pm
Josh
Forum Posts: 1630
Signal Peak Advance Recon
There does not appear to be any snow at the top of the mountain. See picture below.
There is no snow at the trail staging area. See picture below.
B2356A10-ACF1-43E3-A00C-12C0AF00411E.jpegImage Enlarger
DC4AD671-9726-4D5A-833D-4EEFCE44F92B.jpegImage Enlarger
10:06 pm
Josh
Forum Posts: 1630
Signal peak trail run disclaimer:
There’s is no guarantee we will not run into some snow. There are shady parts on this trail. We could come around a corner and run into a 6 foot snow drift. Mother Nature will rule the day. Our goal is to have fun at whatever she allows us to do.
10:12 pm
Josh
Forum Posts: 1630
The plan:
Who’s  going:
Guy & Linda - Chips
David
Greg
Jamie - Maybe
10:12 pm
infotraker
Forum Posts: 55
I plan in going, Jim Ruppel
I will bring dip for the chips
Jim Ruppel
May 17, 2022
8:54 pm
Josh
Forum Posts: 1630
The plan:
Who’s  going:
Guy & Linda - Chips
David
Greg
Jim Ruppel (infotraker) - Dips for chips
Jamie - Maybe
2:28 pm
Folsom4Rnr (Brian)
Folsom, CA
Forum Posts: 607
Josh said
The plan:
Who’s  going:
Guy & Linda - Chips
David
Greg
Jamie - Maybe
I am bummed to post it, but I have to bow out. I found this little guy in my birfield and his friend in the axle angryand now need to get replacements and install them …. Which isn’t happening before the trip unfortunately. I’ll have to catch the next one.
242DF9D2-9854-40E3-9AAD-6BC5324CDE34.jpegImage EnlargerCA5FE9E4-E697-4E30-8DE6-50441C5C2BF3.jpegImage Enlarger
8:00 pm
Josh
Forum Posts: 1630
Understood Brian. Best of luck to you. Hope the repair goes smoothly for you.
8:02 pm
Josh
Forum Posts: 1630
The plan:
Who’s  going:
Guy & Linda - Chips
David
Greg
Jamie - Maybe
10:06 pm
Folsom4Rnr (Brian)
Folsom, CA
Forum Posts: 607
Thank you. I hope it goes well too 🙂
9:44 pm
Josh
Forum Posts: 1630
I’ve looked on social media sites I use. I don’t see any postings of signal peak 2022 yet. Has anyone seen anything on their side?
9:54 pm
Forum Posts: 1991
This was posted 8 hours ago on Nor Cal Jeep FB page when someone asked if anyone had made it to the top yet:
James Kendrick
Negative. It isn't do able at the moment. We cleared a bunch of trees just to get 200 yards from the top and a snow drift blocked the road. Tried to push through but it would just slide you down the mountain
10:37 pm
Josh
Forum Posts: 1630
Thanks Jeff,
200 yards is pretty close.
5:02 am
Forum Posts: 1991
Thanks Jeff,
Good morning Josh. The snow blows over the top of the peak and piles up on the northern side. This makes the snow extra deep on the northern exposure near the peak. That's why the last few yards are typically that last section of the trail to get cleared enough to be able to make it to the peak. Normally you can get up there from the other side but since the road is closed, you only have the difficult side to reach the peak. I saw other people post that they are going this weekend so maybe you will be able to make the peak in a week. Sorry I can't join you. Good luck and have fun.
8:57 am
Josh
Forum Posts: 1630
Thanks Jeff.
That’s the plan!
8:59 am
Josh
Forum Posts: 1630
The plan:
Who’s  going:
Guy & Linda - Chips
David
Greg
Jamie - Maybe
2:09 pm
Forum Posts: 7420
Any thoughts on bringing a few shovels to cut that final part if it still exists on Friday?
Most Users Ever Online: 472
Currently Online: Guy and Lynda
Guest(s) 10
Gregulator: 3113
Jeff_R: 1991
Guy and Lynda: 1446
Gilbert & Betty: 1445
Members: 140
Topics: 4465
Upcoming: Darrell and Jill, Eric and Dawn
