2:42 pm
OfflineWe are meeting at Fresh Pond on Hwy 50 at 830 am, and leaving at 9. There should be lots of people going!
We have two prospects who would like to supply meat for lunch on this run as part of their bbq. Would everyone be up for a simple trail pot luck lunch?
If so, we could use the meat for sandwiches and would only need fixin's bread and some fruit and chips (if everyone covered their own drinks).
Thoughts? I can bring a few large bags of chips...
4:31 pm
I'll be a maybe on this one as well.... had an issue on the way home last night with my exhaust which developed a rather huge crack all the way around the base of the connection to my header. Have to see if I'll be able to get it repaired in time. If I can make it though, I'd be able to bring along something as well.
5:24 pm
Offline"troyman" wrote: I'll be a maybe on this one as well.... had an issue on the way home last night with my exhaust which developed a rather huge crack all the way around the base of the connection to my header. Have to see if I'll be able to get it repaired in time. If I can make it though, I'd be able to bring along something as well.
Can you just swing into a muffler shop and have it welded? It shouldn't be more than a few bucks..
5:45 pm
Yeah, should be a quick fix hopefully. The only deal is that it was already a custom setup where they had modified my header for a solid connection directly to the exhaust. It cracked just under where the header is modified and the exhaust tube starts so it's really close to the oil pan (i.e. pain in the #@$ to get to with a welder). I think I landed on it or something that last run with you guys or the heat mixed with the snow caused it to crack. Either that or it was just a crappy setup 😀
8:02 pm
OfflineLooks like I am out for this weekend. I broke my driver side inner axle on the Rubicon trip. I was hoping it was just another u-joint, but it took out the inner shaft. I am going to order a new shaft, but I don't think I will get it by Sunday. I might hitch a ride with John if that is OK.
3:04 pm
Offline5:20 pm
Offline10:20 pm
OfflineI am a go for this weekend. I got my axle shaft installed. Warn came through. Next day delivery on the shaft and they covered it under warranty 100% no questions asked. That is customer service ![]()
