7:28 pm
7:28 pm
kris_olof
Forum Posts: 1135
March 13, 2015
Offline
Tire squeal or metal on metal squeal? Tire squeal is expected with mini-spool, avoid pavement with anything smaller than tons or you will soon break an axle shaft through fatigue (if the carrier or cross pin doesn't go first.)
If it is a metal squeal, mini-spools load the hell out of small axles. Worn carrier bearings could allow the side loading to push the carrier to make contact with the housing.
August 18, 2015
10:19 pm
10:19 pm
Forum Posts: 7064
Offline
August 19, 2015
6:22 am
6:22 am
Forum Posts: 7064
Offline
August 19, 2015
12:16 pm
12:16 pm
kris_olof
Forum Posts: 1135
March 13, 2015
Offline
August 19, 2015
5:17 pm
5:17 pm
Rayzor
Forum Posts: 276
August 28, 2011
Offline
So pulled it apart again today
My rear caliper is flush against rear rotor
I'm really lost as to wat this issue is an now the seal is leaking
Ugh
Open to suggestions, going to tear it all apart and redo Saturday
Is it possible axle isn't in all the way
Could I be using wrong torque specs
I miss my TJ
1989YJSarah, billyvincent26, chassidyoatley1, heykell, Julie Dwyer, [email protected], follosdin, TerryL, [email protected], Ski manModerators: Posse4x4: 1, BKGM Jeepers: 7064, Lynda and Guy: 226, kris_olof: 1135, Jamie (K6NUB): 781
© Simple:Press —
