Fred is the man!
    #115 Jan 2010, 9:55 AM
    So, I was on the phone with RE today discussing an issue with my JK, and I asked the spring rate question we were discussing at the meeting last night. The 3.5" spring carry the highest rate of the RE springs I asked about (3.5, 4.5, 5.5, 7.5). I also asked about the 5.5 springs and TJ vs. LJ. He said they are the same. This could explain the sagging Bill was talking about. The guy I was talking to also mentioned that people often run the 7.5's in the back of LJ's if they carry a lot of tools and have a hard top.
    FYI, they are under $200 for a pair.
    Thanks to Fred for correcting me with the Tech question of the week!
  2. RobD Subscriber
    #215 Jan 2010, 6:26 PM
    I still run 3.5 springs in the rear of my TJ with the 40 inch tires and I carry a ton of tools and two dogs back there and have no sagging issues.......If I ran 7.5 springs on my Jeep, I would never be able to get in it 😲
    "BKGM Jeepers" wrote: So, I was on the phone with RE today discussing an issue with my JK, and I asked the spring rate question we were discussing at the meeting last night. The 3.5" spring carry the highest rate of the RE springs I asked about (3.5, 4.5, 5.5, 7.5). I also asked about the 5.5 springs and TJ vs. LJ. He said they are the same. This could explain the sagging Bill was talking about. The guy I was talking to also mentioned that people often run the 7.5's in the back of LJ's if they carry a lot of tools and have a hard top.
    #315 Jan 2010, 6:33 PM
    "RobD" wrote: If I ran 7.5 springs on my Jeep, I would never be able to get in it 😲
    You're so old, you can hardly climb into it now 😁
    #415 Jan 2010, 7:50 PM
    Most of the companies that sell Toyota springs recommend a spring with more lift in the rear than the front for the 4Runners. The tops weigh a ton!
  5. RobD Subscriber
    #515 Jan 2010, 8:50 PM
    In your case, it is the water bed and velvet curtains you have in the back of yours that weight so much 😲
    "Bender" wrote: Most of the companies that sell Toyota springs recommend a spring with more lift in the rear than the front for the 4Runners. The tops weigh a ton!
  6. RobD Subscriber
    #615 Jan 2010, 8:53 PM
    It is not that I am old, it's my bad back from all the rocks I have had to stack for you over the years 😁
    "JohnDF" wrote: [quote="RobD"]If I ran 7.5 springs on my Jeep, I would never be able to get in it 😲
    #715 Jan 2010, 9:54 PM
    "RobD" wrote: It is not that I am old, it's my bad back from all the rocks I have had to stack for you over the years 😁
    Okay...that was funny 😂
    #816 Jan 2010, 7:23 AM
    That's why the windows are tinted! 😎
    "RobD" wrote: In your case, it is the water bed and velvet curtains you have in the back of yours that weight so much 😲
    [quote="Bender"]Most of the companies that sell Toyota springs recommend a spring with more lift in the rear than the front for the 4Runners. The tops weigh a ton!
