Project Swaparooni
April 30, 2013
4:23 am
151sp_Permalink sp_Print
Hey, you don't use wood clamps for metal working. 😛
Looks good man! Were you able to get enough heat into the tab? That thing is phat.
April 30, 2013
4:28 am
Forum Posts: 3072
152sp_Permalink sp_Print
Will those be string enough?
5:18 am
153sp_Permalink sp_Print
"Wh1t3Nukle" wrote: Hey, you don't use wood clamps for metal working. 😛
Those are the same wood clamps you tried to press your shackle bushings in with. Don't worry I only used the clamps of mock up and tack.
Yes those babies are 1"x2"x4.5" solid steel. I turned one of them blue. So i might have heated it to Smurf. lol
April 30, 2013
5:19 am
154sp_Permalink sp_Print
"finder_87" wrote: Will those be string enough?
Since your buggie is pretty light they should be strong enough...... lol
April 30, 2013
1:34 pm
Forum Posts: 3072
155sp_Permalink sp_Print
"lj4x4" wrote: [quote="finder_87"]Will those be string enough?
Just make sure the bumper is bolted down 😉
3:38 am
156sp_Permalink sp_Print
Today I cut the gussets and got one side welded in. As usual I made the clearances too tight and had to spend two hours grinding and filing to get the passenger side to fit. But I'm making progress. The esab is working great.
79098=3588-uploadfromtaptalk1367379404726.jpgImage Enlarger 79098=3589-uploadfromtaptalk1367379468429.jpgImage Enlarger 79098=3590-uploadfromtaptalk1367379508124.jpgImage Enlarger
May 11, 2013
4:08 am
157sp_Permalink sp_Print
So after a brief trip to the fire in Ventura I have resumed the bumper fab. I reinforced the center and welded the winch plate to the bumper. The bumper was powder coated and I had to use a stripping wheel on the grinder to get to bare metal. Powder coat is legit. My flap wheel wouldn't get through it.
79328=3609-uploadfromtaptalk1368245224456.jpgImage Enlarger 79328=3610-uploadfromtaptalk1368245242071.jpgImage Enlarger 79328=3611-uploadfromtaptalk1368245284224.jpgImage Enlarger
May 11, 2013
4:28 am
158sp_Permalink sp_Print
More bumper pics
79329=3612-uploadfromtaptalk1368246360310.jpgImage Enlarger 79329=3613-uploadfromtaptalk1368246382130.jpgImage Enlarger 79329=3614-uploadfromtaptalk1368246441684.jpgImage Enlarger
May 11, 2013
4:45 am
159sp_Permalink sp_Print
And yes I painted the hook yellow...
79331=3615-uploadfromtaptalk1368247464775.jpgImage Enlarger 79331=3616-uploadfromtaptalk1368247491115.jpgImage Enlarger
May 11, 2013
4:14 pm
160sp_Permalink sp_Print
Small hook for a winch no workie. 😀
May 30, 2013
6:23 am
161sp_Permalink sp_Print
I finally got the on board air installed. This is the york set up I got from Kean. Of course going from Toyota to Jeep I had to get different brackets and a different pulley. I got the tj bracket and serpantine belt from kilby. The other brackets I fabed up yesterday. All the hoses and wiring were made from stuff lying around the garage. The orange hose is my old compressor hose. Its rated to 300 psi so why not. I still dont have a tank but for now I will run without one. Wired the switch to the cigarette lighter. I also wired in a warning light to blink when the compressor is on its amwsing what you can find on the bling isle at Orilie's. I'm excited to finally have a decent air setup. I'm sure everybody is tired of waiting for me.
79593=3656-uploadfromtaptalk1369894980758.jpgImage Enlarger 79593=3657-uploadfromtaptalk1369895008458.jpgImage Enlarger 79593=3658-uploadfromtaptalk1369895024997.jpgImage Enlarger
May 30, 2013
6:27 am
162sp_Permalink sp_Print
More pics
79594=3659-uploadfromtaptalk1369895157247.jpgImage Enlarger 79594=3660-uploadfromtaptalk1369895208568.jpgImage Enlarger 79594=3661-uploadfromtaptalk1369895220228.jpgImage Enlarger
May 30, 2013
6:43 am
Forum Posts: 3072
163sp_Permalink sp_Print
Nice!!
11:20 pm
Forum Posts: 554
164sp_Permalink sp_Print
I like it!
May 31, 2013
2:42 am
Josh
Forum Posts: 1630
165sp_Permalink sp_Print
Well done Bill. Now I'm the one everyone will be waiting for to finish airing up!
3:36 pm
166sp_Permalink sp_Print
Thanks everyone, I tested the system yesterday after playing arond at pc and found that the old compressor hose isnt up to the heat. The hose blew of the compressor when I was almost finished with the first tire. I think I might try dot air brake line from big rigs and get an air tank. Any body ever used the vinal air line before?
Thanks
May 31, 2013
3:38 pm
167sp_Permalink sp_Print
Some pics from yesterday. The second pic is me turtled on the rock. A little stacking and I was out. Good thing cause nobody was out there.
79625=3662-uploadfromtaptalk1370014640198.jpgImage Enlarger 79625=3663-uploadfromtaptalk1370014650727.jpgImage Enlarger
May 31, 2013
3:56 pm
168sp_Permalink sp_Print
"lj4x4" wrote: Thanks everyone, I tested the system yesterday after playing arond at pc and found that the old compressor hose isnt up to the heat. The hose blew of the compressor when I was almost finished with the first tire. I think I might try dot air brake line from big rigs and get an air tank. Any body ever used the vinal air line before?
Thanks
I just saw your install pics and was going to warn you about the heat. York compressors throw out a tremendous amount of heat. I used the goodyear insta-grip hose. I think I got it from home depot. It is rated to 190 degrees which I'm sure you'll get above but it always held up for me. I assume it's because it has a healthy safety factor and can go to a higher temperature, you just start loosing the pressure rating. I used it to fill my 37s and a friends 35s back to back with no problems.
I also never used a tank. I always thought about getting one but just never really had a reason to. You'd probably need it to run air tools or set a bead but air tools always just seemed too heavy to carry with me. I also used 3/8" line so it could move a fair amount of air. Filling up tires even without a tank it was about as fast as my CO2 setup.
http://www.goodyearep.com/prod.....px?id=1408
May 31, 2013
7:08 pm
Forum Posts: 3072
169sp_Permalink sp_Print
I use big rig dot air lines everyday. I wonder what they're rated at cause my system doesn't go above 150 psi.
8:53 pm
170sp_Permalink sp_Print
"finder_87" wrote: I use big rig dot air lines everyday. I wonder what they're rated at cause my system doesn't go above 150 psi.
What kills the lines in this case isn't the pressure. It's the heat. The pressure switch and pop off ensure that the pressure doesn't get crazy but the heat melts them.
June 1, 2013
1:15 am
Forum Posts: 7066
171sp_Permalink sp_Print
"Bender" wrote: [quote="finder_87"]I use big rig dot air lines everyday. I wonder what they're rated at cause my system doesn't go above 150 psi.
Yes. I used to have heat problems until I swapped my lines out.
June 1, 2013
4:04 am
Forum Posts: 554
172sp_Permalink sp_Print
Hey me too.
June 2, 2013
4:45 am
173sp_Permalink sp_Print
Ill look fot the Goodyear hose at hd. That would be the easiest solution. And it does get crazy hot under the hood.
June 10, 2013
7:42 pm
174sp_Permalink sp_Print
I finally found an air hose I think will work. Out of several auto part stores and the big three home improvements Lowes had high pressure/ high temperature reinforced pvc hose. I hope it will work.
79776=3686-uploadfromtaptalk1370893336184.jpgImage Enlarger
June 18, 2013
8:59 pm
175sp_Permalink sp_Print
Well guess what, I don't work. It blows off and before that it blows up like a sausage. I'm back in the hunt for hose. I called about steel braided with jic fittings but they wanted 90 bucks. Too rich for my blood.
Currently Online: Mike G
Members: 145
lavinasteinman8, 1989YJSarah, billyvincent26, chassidyoatley1, heykell, Julie Dwyer, [email protected], follosdin, TerryL, [email protected]
Moderators: Posse4x4: 1, BKGM Jeepers: 7066, Lynda and Guy: 227, kris_olof: 1135, Jamie (K6NUB): 781
Administrators: k-jeep: 2241
