Springs Vs. Spacers
    #118 Jul 2013, 9:57 AM
    I am looking to gain an 1"-2" of clearance for my JK. Currently, I have a 3.5" Teraflex lift (springs, shocks, control arms, etc). I am looking at either replacing my 3" springs with 4" springs, or keeping my existing springs and adding the JKS adjustable coil spacers. Any thoughts or suggestions?
    #218 Jul 2013, 11:42 AM
    Ive done both approaches.
    If you know your final height, then sprins are good. If you are still evolving, I suggest ACOS because they can be continually adjusted as you change things (add a winch, change a winch, replace wire with rope, change a front bumper or add taller rear springs).
    #318 Jul 2013, 11:58 AM
    Do you have long control arms?
  4. Josh Subscriber
    #418 Jul 2013, 12:13 PM
    "cyacoub" wrote: I am looking at either replacing my 3" springs with 4" springs, or keeping my existing springs and adding the JKS adjustable coil spacers. Any thoughts or suggestions?
    I run both. ACOS provide you options as you evolve your rig setup. You can expand up or down as your needs change.
    #518 Jul 2013, 1:09 PM
    A stock JKU control arm is the equivilent of a mid arm set up on a TJ. They are fine with 4" or even 5" of lift.
    Above 5" of lift could cause similar geometry we saw in Tj's running lifts with short arms.
    #618 Jul 2013, 1:36 PM
    Acos are good for when the driver gains weight the jeep will have nice lean. Acos will fix that.
  7. Josh Subscriber
    #718 Jul 2013, 5:32 PM
    "finder_87" wrote: Acos are good for when the driver gains weight the jeep will have nice lean. Acos will fix that.
    That's what happens when you eat to much pizza. This is what happens if you drive a trugy do to the lack of a heater or roof.
    #818 Jul 2013, 10:27 PM
    "BKGM Jeepers" wrote: A stock JKU control arm is the equivilent of a mid arm set up on a TJ.
    Oops, I missed that it was a JK. I haven't moved out of the 20th century yet 😳
    #919 Jul 2013, 6:50 AM
    Thats what happens when you own both!
  10. huck271 Subscriber
    #1022 Jul 2013, 1:07 AM
    If you are going 4-5" I recommend getting adjustable control arms to keep the pinion angle help with geometry.
    #1122 Jul 2013, 6:51 AM
    "BKGM Jeepers" wrote: Thats what happens when you own both!
    Yes, well I've modified the crap out of one and have done absolutely nothing to the other. I obviously know my TJ inside and out, but I'm lucky I even know how to start my JK 🙂
    #1222 Jul 2013, 11:09 AM
    "JohnDF" wrote: [quote="BKGM Jeepers"]Thats what happens when you own both!
    What are you waiting for? I want to see John on the trails!!
    #1322 Jul 2013, 4:40 PM
    Looks like the ACOS spacers are the way to go. I already have TeraFlex adjustable upper and lower Control Arms and Track bars, so the only issue I am worried about now is the drive shafts. I just noticed that I am already cutting a groove in my front driveshaft where it is rubbing on the transmission skid plate. I am still running the OEM drive shafts with the slip yokes. Anyone else run into this problem on their JKU? Did you change the drive shaft, and what did you go to?
  14. huck271 Subscriber
    #1422 Jul 2013, 5:35 PM
    "cyacoub" wrote: Looks like the ACOS spacers are the way to go. I already have TeraFlex adjustable upper and lower Control Arms and Track bars, so the only issue I am worried about now is the drive shafts. I just noticed that I am already cutting a groove in my front driveshaft where it is rubbing on the transmission skid plate. I am still running the OEM drive shafts with the slip yokes. Anyone else run into this problem on their JKU? Did you change the drive shaft, and what did you go to?
    When you go over 2" aftermarket drive shafts are in order. If you are keeping the stock skid plates they will need to be notched to avoid contact at full droop
