School me on trailers.|Page 7|General Chit Chat|Forum|Gold Hills Posse 4x4
February 25, 2008
9:09 pm
151sp_Permalink sp_Print
"Howdy" wrote: I may be missing something, but if you took out the rear driveshaft and just unlocked the front hubs couldn't you just put your auto in nuetral?
Yeah, if you did this you could do pretty much anything you want with the engine, trans & t-case. You could even leave the engine running, trans in reverse and t-case in 4-low. lol
February 25, 2008
9:20 pm
152sp_Permalink sp_Print
"Justin" wrote: [quote="Bender"] Can you get a dolly that will safely hold onto 37s? Oh wait...safety isn't a concern. Just use bungee cords to hold the front wheels on the dolly. lol
I don't think I have seriously condoned unsafe towing since this thread was started. So yes, safety is a concern with me. I'm towing a $30k Jeep behind a expensive RV that doesn't belong to me. But, I never thought about useing bungee cords.............I might look into that.[Image Can Not Be Found]
I was acutally half serious (the first half). Can the tie down areas on most dollys fit a 37? They're typically used on a vehicle with much smaller tires. Is the "cup" that the tire sits in big enough to keep a 37 in place? Are the straps long enough? Maybe it's a non issue. I have no dolly experience, I was just trying to come up with things to check.
"FAM" wrote: You could even leave the engine running...
That would certainly help to maximize fuel usage. 😀
February 25, 2008
9:52 pm
Justin
Forum Posts: 1416
153sp_Permalink sp_Print
I have some 31" tires on wheels in case I need to run a smaller tire for a trailer or dolly. I figured I could put two 37"s in the back of the Jeep if I go that route. (smaller front tires for a dolly).
I also thought about if I break something that renders my Jeep unable to be flat towed or dollied, I could rent a u-haul trailer down south for $50 to tow the Jeep home.
February 25, 2008
10:23 pm
Forum Posts: 7479
154sp_Permalink sp_Print
"Justin" wrote: I have some 31" tires on wheels in case I need to run a smaller tire for a trailer or dolly. I figured I could put two 37"s in the back of the Jeep if I go that route. (smaller front tires for a dolly).
Great plan with the dolly. I didn't think about the smaller tire idea! Also, Rob could toss the tires in his truck if he had to. Plus dolly's are cheap and don't have a mileage restriction!
10:36 pm
155sp_Permalink sp_Print
"Justin" wrote: (smaller front tires for a dolly).
Sweet...It would look like a dragster! lol
February 25, 2008
10:41 pm
156sp_Permalink sp_Print
I was just poking around a bit regarding tow dollies. It seems they're generally meant for smaller lighter cars and may marginally have enough load capacity for a built up & armored Jeep. Width of the Jeep might be a problem too. Here's a link to U-Haul to get you started on the specs.
http://www.uhaul.com/guide/index.aspx?e ... g-towdolly
February 25, 2008
10:44 pm
157sp_Permalink sp_Print
"Bender" wrote: [quote="Justin"] (smaller front tires for a dolly).
Didn't Rob post some pictures of his Jeep with little front tires a while back?
February 25, 2008
11:06 pm
Justin
Forum Posts: 1416
158sp_Permalink sp_Print
"FAM" wrote: I was just poking around a bit regarding tow dollies. It seems they're generally meant for smaller lighter cars and may marginally have enough load capacity for a built up & armored Jeep. Width of the Jeep might be a problem too. Here's a link to U-Haul to get you started on the specs.
Yeah, I saw the specs on the Uhaul web site but, I have found heavy duty dollies that are designed for bigger vehicles. (buddy has one that I could possibly borrow).
February 25, 2008
11:56 pm
159sp_Permalink sp_Print
Just hope you don't break the rear end 😯
12:22 am
Forum Posts: 7479
160sp_Permalink sp_Print
"JohnDF" wrote: Just hope you don't break the rear end 😯
Lock the steering wheel in straight and tow it backwards! If you have hubs there are no problems. If not, remove the front driveline.
12:33 am
161sp_Permalink sp_Print
embarassed I've never used a dolly. I didn't know that was possible embarassed
12:33 am
162sp_Permalink sp_Print
"BKGM Jeepers" wrote: [quote="JohnDF"]Just hope you don't break the rear end 😯
Apparently this too is arguable whether or not its a good idea. I have no personal comment since I've never used a tow dolly, but here's a short discussion of the idea.
http://www.rv.net/forum/index.cfm/fusea ... m#20949094
February 26, 2008
1:17 am
163sp_Permalink sp_Print
"JohnDF" wrote: [quote="BKGM Jeepers"]
According to you anything is possible. Just do it. Don't worry, Keane is in Grassvalley, so you won't be putting him in danger with your irresponsibility lol lol lol lol
JUST KIDDING 😀
February 26, 2008
2:10 am
Justin
Forum Posts: 1416
164sp_Permalink sp_Print
Like I said before, if it comes to something like that, I will just rent a trailer down there and tow the Jeep home. 8)
February 26, 2008
2:12 am
165sp_Permalink sp_Print
We can't even find an ice cream shop down there and you want to find a u-haul shop??? Good luck wink
P.S...
You guys worry too much about breaking 😛
2:20 am
Justin
Forum Posts: 1416
166sp_Permalink sp_Print
I will just live in the RV while I go to the nearest town with Uhaul rentals. lol
And John, I worry if I have nothing to worry about. wink
February 26, 2008
3:14 pm
167sp_Permalink sp_Print
"RobD" wrote: According to you anything is possible. Just do it. Don't worry, Keane is in Grassvalley, so you won't be putting him in danger with your irresponsibility lol lol lol lol
I have a very sensitive stomach. Your recklessness will cause me to worry resulting in extreme gas. Kelly will not be happy. You'd best skip a meeting or two until she cools down a bit. lol
February 26, 2008
6:13 pm
Justin
Forum Posts: 1416
168sp_Permalink sp_Print
"JohnDF" wrote: We can't even find an ice cream shop down there
Ice Cream will be in the freezer. 8)
Heck, we could bring a espresso machine for Rob to make his sissy la la drinks.
February 26, 2008
6:44 pm
169sp_Permalink sp_Print
"Justin" wrote: [quote="JohnDF"]We can't even find an ice cream shop down there
Ice cream and sissy-lattes...Rob may never leave lol
7:45 pm
170sp_Permalink sp_Print
"JohnDF" wrote: [quote="Justin"][quote="JohnDF"]We can't even find an ice cream shop down there
Add in a foot massage after the day of wheeling, and I know I will never leave lol lol lol lol lol lol
February 26, 2008
8:19 pm
171sp_Permalink sp_Print
Better talk to Justin's buddy (we can call it part of his trail duties) because I aint touching your feet 😯 I bet your wife won't even touch your feet lol
8:45 pm
172sp_Permalink sp_Print
"RobD" wrote: [quote="JohnDF"][quote="Justin"][quote="JohnDF"]We can't even find an ice cream shop down there
Would you give a guy a foot massage?!
(Movie?)
February 26, 2008
9:11 pm
173sp_Permalink sp_Print
"Bender" wrote:
(Movie?)
Don't get Rob started on his favorite movie. I wonder if Rob and Howdy watched it together?
10:17 pm
Justin
Forum Posts: 1416
174sp_Permalink sp_Print
(Movie?)
Ooh ooh too easy......can I answer.....can I ......can I......??????
February 26, 2008
10:23 pm
175sp_Permalink sp_Print
Is it a movie line? I guess I thought you were talking about Rob's favorite "Brokeback."
Guest(s) 28
Jeff_R: 2073
Gilbert & Betty: 1454
Members: 146
Topics: 4490
