11:03 am
January 20, 2009
Offline3:26 pm
January 20, 2009
Offline7:24 pm
Offline7:55 pm
Offline8:12 pm
January 20, 2009
Offline4:45 pm
OfflineTalked to Trevor at WFO about the brake cable to see why it was mounted under the control arm. I was just curious, you never know, there may have been a legitimate reason for doing it that way. Turns out a customer had his brake cable melted by the exhaust so the tech installed mine below to keep it from melting. I am going to move it back up and zip-tie it so it doesn't contact the exhaust. Mystery solved.
Also, my stock drive lines are up at WFO if anybody has need of them. You'd just have to run up there and pick them up.
6:24 pm
OfflineJohnDF said
Talked to Trevor at WFO about the brake cable to see why it was mounted under the control arm. I was just curious, you never know, there may have been a legitimate reason for doing it that way. Turns out a customer had his brake cable melted by the exhaust so the tech installed mine below to keep it from melting. I am going to move it back up and zip-tie it so it doesn't contact the exhaust. Mystery solved.Also, my stock drive lines are up at WFO if anybody has need of them. You'd just have to run up there and pick them up.
So the tech felt that placing the brake line in contact with rocks was the better option?
'"O" stands for open, and not off road. That was my bad...
Ill stop being a smart A%@ now.
9:20 pm
January 20, 2009
Offline10:28 pm
Offline5:58 am
Offline1:57 pm
OfflineGregulator said
John, how close is your rear track bar to your diff cover?
It's tight but it clears...
Actually, ALL the clearances are very, very tight with only 3 inches of lift.
The tie rod, drag link, and track bar bracket are almost touching at full turn and droop.
It took a lot of "tweaking" by WFO to get everything to fit "just right". But by the time they were done everything fits perfectly and cycles fully without contact.
Glad I paid to have it done LOL.
7:20 pm
Offline8:12 pm
Offline1 Guest(s)
