1:51 am
2:18 am
My TJ had a cyl-6 misfire code too. It would sometimes also through cylinder 2 misfire codes as well. it was very frustrating, especially since my jeep only had 30K. I already had a reader so I was able to quickly identify the problem. I solved the problem by buying a new coil pack for $50 off Ebay and installing new plugs. I gave the buyer my old pack as a "spare" when I sold it to him. I told him the smog problem but that it did pass without being coded gross polluter. He was from Reno, and said "Nevada doesn't care, but thanks any ways"!
4:29 pm
11:50 pm
12:58 am
Got the head back from Bud Walmer's machine shop. He said it was bad and the valve seat was offset by almost a quarter of an inch in cylinder six. He did a vacuumtest prior to machinig and they all had significant leaks. Now she is purdy and should run like a top. Of course after I put everything back togeather. I'm dreading installing the intake and exhaust manifold. It was a pita to get off and I have no idea how I'm going to start the bottom bolts. We will see.
1:47 am
1:15 am
January 27, 2011
3:12 am
January 27, 2011
3:52 am
"Wh1t3Nukle" wrote: [quote="TomD"]I was just curious about miles. My XJ is ~160K so was checking.
How's your compression? Bill can check it in his sleep now!
Yes we can check your compression but I doubt you will a have a similar situation to me. You actually care about your motor and maintain it.
4:10 am
I'm screwed! The motor needs a total rebuild. I drove the Jeep to Yuba City today for a class. As I arrived the check engine came on....again.... The code was cylinder six misfire 👿 . I have tried everything and the only thing left is a rebuild. Yes I could pull the piston drill hone the cylinder and put new rings on. This would only fix one cylinder and the rest of them are still beat to sh@#. It would be unethical and sleazy to knowingly sell a vehicle with a blown motor to anyone. So even though I can't afford it, I will be pulling the motor next week. I'm not sure how to get it to and from the machine shop, so I might ask for some assistance. Please excuse my but i'm not happy.
5:02 am
