April 26, 2010
6:24 pm
226sp_Permalink sp_Print
Justin, I got the bends done by a buddy of mine that owns off road addiction up here in Auburn. Problem is that I had to much bend put in them. They hit the back of the tire on full stuff. Heading over to his shop to take about 2 inchs of Z bend out. I did flex test the jeep yesterday with it attached. Huge difference. At the top of my flex ramp, the jeep used to feel real tippy. With the rear sway bar hooked up, the jeep was solid as a rock!!!!! On the road, night and day. Really feels like driving a sports car again. Almost no body sway at all.
April 26, 2010
7:45 pm
Justin
Forum Posts: 1416
227sp_Permalink sp_Print
"RobD" wrote: Justin, I got the bends done by a buddy of mine that owns off road addiction up here in Auburn. Problem is that I had to much bend put in them. They hit the back of the tire on full stuff. Heading over to his shop to take about 2 inchs of Z bend out. I did flex test the jeep yesterday with it attached. Huge difference. At the top of my flex ramp, the jeep used to feel real tippy. With the rear sway bar hooked up, the jeep was solid as a rock!!!!! On the road, night and day. Really feels like driving a sports car again. Almost no body sway at all.
Cool. Thanks! I guess I'll order one and go talk to them about bending mine. I did order a Swayloc for the front yesterday. 8) There is no way I want to wheel another season without any sway bar.
April 26, 2010
8:09 pm
228sp_Permalink sp_Print
Before you bend yours, hook up with me and lets test fit your arms first. You may not need to bend them. You don't have the stretched wheel base and your spring buckets are stock unlike mine. I already went through the learning curve on the installation embarassed
April 26, 2010
8:44 pm
Justin
Forum Posts: 1416
229sp_Permalink sp_Print
"RobD" wrote: Before you bend yours, hook up with me and lets test fit your arms first. You may not need to bend them. You don't have the stretched wheel base and your spring buckets are stock unlike mine. I already went through the learning curve on the installation embarassed
Sounds good. Thanks Rob! 8)
April 26, 2010
11:53 pm
Forum Posts: 7064
sp_UserOnlineSmall Online
230sp_Permalink sp_Print
What's the advantage of the new sway bar over stock? Is the advantage stability off camber? articulation off-road? smoother travel because of improved geometry? Something else? Is it becuase the stretch renders the stock set up unusable?
What caused the change?
April 27, 2010
3:16 am
231sp_Permalink sp_Print
Same thing that anyone running a rear Dana 60 has. The stock sway bar doesn't work, and cheap after market one's like the kind you and John got from Lee will bend when you wheel them. The Genright sway bar has a ton of benefits to it. Body roll, off camber, and it works with my stretched wheel base. The change was that I haven't been running a rear sway bar for years now and decided to take the plunge and put one back on. It isn't cheap, the kit is $500 and if you can't install it yourself, it will cost another $200 or more to have someone install it for you.
"BKGM Jeepers" wrote: What's the advantage of the new sway bar over stock? Is the advantage stability off camber? articulation off-road? smoother travel because of improved geometry? Something else? Is it becuase the stretch renders the stock set up unusable?
April 27, 2010
3:25 am
232sp_Permalink sp_Print
Rear sway baes are for sissies mr-green
3:49 am
233sp_Permalink sp_Print
"JohnDF" wrote: Rear sway baes are for sissies mr-green
Say that when one of my tires are sitting on your hood 😈
April 27, 2010
4:56 am
234sp_Permalink sp_Print
"RobD" wrote: [quote="JohnDF"]Rear sway baes are for sissies mr-green
You can't drive over anything without me spotting you mr-green
1:59 pm
235sp_Permalink sp_Print
Front sway bars are for sissies. 😈
April 27, 2010
2:34 pm
236sp_Permalink sp_Print
Your right, sway bars are for sissies, but leaf springs are for little girls mr-green
"Bender" wrote: [quote="JohnDF"]Rear sway baes are for sissies mr-green
April 27, 2010
2:41 pm
237sp_Permalink sp_Print
Best thread ever...bunch of tech and off topic cr@p slingin' all in one. 8)
3:04 pm
Forum Posts: 7064
238sp_Permalink sp_Print
"RobD" wrote: Same thing that anyone running a rear Dana 60 has. The stock sway bar doesn't work, and cheap after market one's like the kind you and John got from Lee will bend when you wheel them. The Genright sway bar has a ton of benefits to it. Body roll, off camber, and it works with my stretched wheel base. The change was that I haven't been running a rear sway bar for years now and decided to take the plunge and put one back on. It isn't cheap, the kit is $500 and if you can't install it yourself, it will cost another $200 or more to have someone install it for you.
[quote="BKGM Jeepers"]What's the advantage of the new sway bar over stock? Is the advantage stability off camber? articulation off-road? smoother travel because of improved geometry? Something else? Is it becuase the stretch renders the stock set up unusable?
I do have to agree about the bending becuase I have bent mine already, and I don't even wheel! I didn't think you could even consider some type of stock set up becuase your stretch makes the frame connections too far forward. Is that not the case?
Also, the JK already has the same style set up as yours, but from the rear (though less beefy and cheap quality). It would be an easy product design to get your set up back there. I wonder how long it will be until someone figures it out and designs a JK version. It could even be done without any welding...
April 27, 2010
3:44 pm
k-jeep
Parts Unknown
Forum Posts: 2240
239sp_Permalink sp_Print
"RobD" wrote: Your right, sway bars are for sissies, but leaf springs are for little girls mr-green
lol
Funny how this little girl with leaf springs and 33s followed you with your coil springs and 40s through Fordyce. mr-green
Yeah, yeah, I needed a few rocks stacked, but still. mr-green
lol
I want to do that one again this summer now that I have 35s and low range. Hope my axles survive!
April 27, 2010
4:12 pm
240sp_Permalink sp_Print
Kevin's getting cocky...time to take him to the Hammers beer
4:29 pm
k-jeep
Parts Unknown
Forum Posts: 2240
241sp_Permalink sp_Print
"JohnDF" wrote: Kevin's getting cocky...time to take him to the Hammers beer
Someday, but not until I get some D60s. I think my current axles would snap like toothpicks on the Hammers. mr-green
April 27, 2010
4:41 pm
Forum Posts: 7064
242sp_Permalink sp_Print
Uh oh - he's moving on from light beer!!!! beer
April 27, 2010
5:04 pm
243sp_Permalink sp_Print
"BKGM Jeepers" wrote: [quote="JohnDF"]Kevin's getting cocky...time to take him to the Hammers beer
lol It's Miller Time lol
5:37 pm
Justin
Forum Posts: 1416
244sp_Permalink sp_Print
"JohnDF" wrote: ...time to take him to the Hammers beer
Did somebody say HAMMERS?
April 27, 2010
5:39 pm
Justin
Forum Posts: 1416
245sp_Permalink sp_Print
Oh and Rob, after I saw the price on the rear sway bar, I decided it will be a little while before I order one. 😡 I thought they were a few hundred dollars cheaper. embarassed
April 27, 2010
5:58 pm
246sp_Permalink sp_Print
A few hundred cheaper? How much do they cost?
6:25 pm
247sp_Permalink sp_Print
$500
"JohnDF" wrote: A few hundred cheaper? How much do they cost?
April 27, 2010
6:26 pm
248sp_Permalink sp_Print
The Currie rear antirock is a little cheaper, but isn't a complete kit like the Genright and the arms on the Genright are 1/2 inch steel unlike the 1/4 inch currie arms..
April 27, 2010
6:28 pm
249sp_Permalink sp_Print
Your axles will hold up just fine as long as you stay on 35's..You do have chromo shafts right?
"kevheb" wrote: [quote="JohnDF"]Kevin's getting cocky...time to take him to the Hammers beer
April 27, 2010
6:29 pm
250sp_Permalink sp_Print
Let me test mine out for the summer and then I will give you an opinion on it and then you can decide if it is worth it for you!!
"Justin" wrote: Oh and Rob, after I saw the price on the rear sway bar, I decided it will be a little while before I order one. 😡 I thought they were a few hundred dollars cheaper. embarassed
Currently Online: BKGM Jeepers
