April 7, 2010
4:19 am
201sp_Permalink sp_Print
Looks good. Time to lose the body lift 😈
3:25 pm
Anonymous
202sp_Permalink sp_Print
Rake the windshield and paint it orange?
58393=2402-jeeplowerfortylive_07.jpgImage Enlarger
April 11, 2010
3:32 am
203sp_Permalink sp_Print
MY two newest items to my build 😀 John is coming over tomorrow to help me install the York compressor....
Genright rear sway bar 8)
[Image Can Not Be Found]
Kilby OBA Airboss 8)
April 11, 2010
4:34 am
204sp_Permalink sp_Print
I guess if you NEED a swaybar 😛
5:08 am
205sp_Permalink sp_Print
It's all about the looks. If it looks kewl; it is kewl mr-green
"JohnDF" wrote: I guess if you NEED a swaybar 😛
April 11, 2010
5:12 am
206sp_Permalink sp_Print
"RobD" wrote: It's all about the looks. If it looks kewl; it is kewl mr-green
I look kewl 8)
2:38 pm
207sp_Permalink sp_Print
Rob's York install was very straight forward and easy. His oil return system is sweet!
4:11 pm
208sp_Permalink sp_Print
so i guess he's all done. nice work rob. now how much u selling the jeep for? 😛 lol
April 15, 2010
1:24 am
209sp_Permalink sp_Print
York is all installed and up and running. Very nice to have unlimited air. Runs my air tools with no problems!!!!!! The 1.75 gallon tank was a tight fit!!!! It is on the driver side tucked into the back corner by the rear spring.
Shot with Canon PowerShot SX210 IS at 2010-04-14
Shot at 2010-04-14
April 15, 2010
3:02 am
210sp_Permalink sp_Print
How does the oil return system work with the compressor up that high? Does the air pressure actually blow it back in?
April 15, 2010
3:14 am
211sp_Permalink sp_Print
What happens is that the air output from the compressor to the manifold goes through an oil filter and reservoir. The reservoir holds the excess oil until full. When that happens, I leave the compressor running and open a valve at the bottom of the oil reservoir and the air pressure pushes the excess oil in the reservoir back into the compressor to re-use it. It is a pretty slick system.....
April 16, 2010
7:34 pm
212sp_Permalink sp_Print
I did a time check on filling a tire with the York today. With a 40 inch tire deflated to 2 pounds, it took the York 1 minute 38 seconds to fill it back up to 30 pounds. I only run 22 pounds of pressure on the street, so my air time will be around 1 minute to fill each tire. I like it mr-green
April 16, 2010
11:52 pm
213sp_Permalink sp_Print
That sounds good to me. Nice mod Rob.
12:35 am
214sp_Permalink sp_Print
That sounds great!
April 17, 2010
3:44 am
215sp_Permalink sp_Print
Rear sway bar showed up today and will be installed this week.
April 19, 2010
4:34 am
Dan-H
Forum Posts: 1378
216sp_Permalink sp_Print
Rob,
out of curiosity, where's your checkvalve?
2:34 pm
217sp_Permalink sp_Print
"Dan-H" wrote: Rob,
On the driver side inner fender.
April 19, 2010
3:02 pm
218sp_Permalink sp_Print
I don't think you can fit any more stuff under that hood lol
2:53 am
219sp_Permalink sp_Print
I got most of the sway bar system installed today. I just need to take the arms to a metal shop tomorrow and get a "Z" bend put in them to clear my rear springs...
First step was to cut some of the fender well trim to get the outer tube in position from frame rail to rail
Shot with Canon PowerShot S90 at 2010-04-19
Next was to clean up the frame rail for the weld on brackets that hold the sway bar outer tube in position
Next was to tack weld the brackets in place
Then everything went on to test fit and make sure everything was working!!
Brackets get the final weld
Arms in place.
Shot at 2010-04-19
Tomorrow, I will have a Z bend put in the arms then build the links and weld the tab on the axle and call it good!!!!
April 20, 2010
1:45 pm
Justin
Forum Posts: 1416
220sp_Permalink sp_Print
Nice Rob! Your welds are looking good.
Outboarding my shocks and that sway bar are two mods I want to do soon.
April 20, 2010
4:22 pm
221sp_Permalink sp_Print
Thanks, out-boarding the shocks was one of the best mods for the rear axle I did. Huge performance gain...With the addition of the rear sway bar, the front and the rear will work together for off road traction. Most important, it will really help with body roll in off camber situations, and I seem to spend a lot of time in those situations 😈
"Justin" wrote: Nice Rob! Your welds are looking good.
April 20, 2010
7:55 pm
222sp_Permalink sp_Print
"RobD" wrote: Thanks, out-boarding the shocks was one of the best mods for the rear axle I did. Huge performance gain...With the addition of the rear sway bar, the front and the rear will work together for off road traction. Most important, it will really help with body roll in off camber situations, and I seem to spend a lot of time in those situations 😈
. Quit quoting Blaine. It makes you sound like one of his clones.
8:34 pm
223sp_Permalink sp_Print
Well I tried to get the perfect 50/50 balance between the front and rear, but failed, so I settled on a swaybar 🙂 and don't be a Blaine hater. Some people idolize him!!!!!
"JohnDF" wrote: [quote="RobD"]Thanks, out-boarding the shocks was one of the best mods for the rear axle I did. Huge performance gain...With the addition of the rear sway bar, the front and the rear will work together for off road traction. Most important, it will really help with body roll in off camber situations, and I seem to spend a lot of time in those situations 😈
April 21, 2010
12:09 am
224sp_Permalink sp_Print
I'm not a Blaine hater...he's a great source of entertainment.
5:38 pm
Justin
Forum Posts: 1416
225sp_Permalink sp_Print
"RobD" wrote: I got most of the sway bar system installed today. I just need to take the arms to a metal shop tomorrow and get a "Z" bend put in them to clear my rear springs...
Did you get the bend done to the arms? If so, who did it?
Currently Online: BKGM Jeepers
